2002 Chevy Impala Oil in Coolant
64,154 MILES • 6 CYL • FWD • AUTOMATIC
ELLEN H
My dealership says there is oil in my coolant, from a gasket leak. I understand it should be fixed. They recommend a gasket replacement and coolant flush. But in the near term, is it a SAFETY issue?
May 12, 2010 at 8:08 AM
BLUELIGHTNIN6
  • 16,542 POSTS
sounds like the cylinder head gasket has failed, allowing coolant to mix with the engine oil. you can drive the vehicle this way for a short while, just keep an eye on the temperature gauge so that the engine doesn't overheat.
May 12, 2010 at 8:11 AM
