2002 Chevy Impala NOISE FROM DRIVERS SIDE FRONT BRAKE
70,000 MILES • 6 CYL • FWD • AUTOMATIC
LEMY
MY HUSBAND REPLACED ALL FOUR BRAKES WITH UPGRADED NEW BRAKES AND ROTORS LAST YEAR.
MY CAR MAKES A SQUEALING NOISE ON THE FRONT DRIVERS SIDE. IT IS QUITE ANNOYING AND LOUD. MY QUESTION IS WHY DOES IT ONLY DO IN THE FRONT DRIVERS SIDE AND WHY. IS THERE ANYTHING WE CAN DO TO STOP THIS AND ALSO IS IT A DRIVING HAZARD?
May 26, 2010 at 11:10 PM
BMRFIXIT
  • 19,053 POSTS
noise happens only when braking
,brakes should be rechecked
check pads and shims
use synthetic grease and lube contact points
May 26, 2010 at 11:13 PM
  • 75,988 POSTS
New rotors should be refinish or applying brake grease or noise compound to the back of the pads
May 26, 2010 at 11:17 PM
