2002 Chevy Impala Low beam lights
185,000 MILES • 6 CYL • FWD • AUTOMATIC
JACKSONB
Low beam lights will not turn on until the car is warm.
This happens when the car is cold or its very wet.
The light sensor not turning light on at night until car is warm.
When its warm the car operates normally.
The lens looks cloudy inside. In the past clicked on the high beam to to reset low beam light. Is it a switch problem or sensor? The problem is getting worse.
Mar 19, 2009 at 4:38 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Need for you to check out a ground connection. Open hood see junction box on right side as you face engine. Look for small black wire comming from bottom of box over to the radiator support. See if it is clean and tight.
Let me know
Also do Daytime Running Lights function?
Thanks for donate
Mar 19, 2009 at 5:48 AM
