2002 Chevy Impala loss of low fan speeds
870,000 MILES • 6 CYL • FWD • AUTOMATIC
AL GOSSELIN
Just noticed that my fan doesn't work in the first 2 speeds, but works fine 3,4, &5. Could the problem be a fuse for the lower fan speeds?
Feb 20, 2008 at 11:02 AM
FISHERMAN
  • 937 POSTS
[quote:08bbd01d02="Al Gosselin"]Heater problem
2002 Chevy Impala 6 cyl Front Wheel Drive Automatic 870000 miles
Just noticed that my fan doesn't work in the first 2 speeds, but works fine 3,4, &5. Could the problem be a fuse for the lower fan speeds?[/quote:08bbd01d02]
Hello !!
check the blower fan resistor, that should solve your problem!
The blower motor resistor its located on HVAC module, below blower motor.
let us know if you need a picture of it!
good luck!
Feb 20, 2008 at 11:21 AM
FISHERMAN
  • 937 POSTS
As your request (e-mail) here`s the schematic of the blower motor resistor location:
https://images.2carpros.com/forum/automotive_pictures/576_0_14.jpg
Feb 21, 2008 at 10:27 AM
GJULIAN12
Is this located under the glove box or under the hood?
Nov 18, 2008 at 1:01 PM
