2002 Chevy Impala Hard starts / stalls
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAKIMPALA
Problems started with hard starting mostly when the car was warm. It would not start warm with no accelerator pedal. A small depression of the accelerator pedal and it would usually start. I still have that problem but now the car will occasionally stall when turning a corner or coming to a stop. As a test, in nuetral, if I tap the accelerator pedal a number of times, I can occasionally see that engine RPMs drop and the engine will almost stall. A ECM scan throws codes. I am overdue for a fuel filter replacement. Where do you suggest that I start troubleshooting?
Mar 9, 2010 at 4:41 AM
LEGITIMATE007
  • 5,121 POSTS
do your fuel filter and then start with the idle air control valve. A good throttle body cleaning and then let me know how that goes, you said its throwing codes? or its not throwing codes, if it is, what codes are they?
Mar 9, 2010 at 4:52 AM
