2002 Chevy Impala Front brake pads
175,000 MILES • 6 CYL • FWD • AUTOMATIC
BLACKLANDER
Does it matter which side of rotor that you install the brake pad wear indicator? Is it just used for visual check or is it supposed to make noise when it wears to the point of touching the rotors?
Sep 22, 2010 at 11:29 AM
SATURNTECH9
  • 30,868 POSTS
Important: The wear sensor is on the outside pad. The sensor is positioned at the leading or upward edge of the pad during forward wheel rotation.
The sensor make's noise when the pad get's low by scraping the rotor's surface.
Mar 29, 2021 at 5:28 AM
