Do you need to buy motor with the brackets attached? And can you show me how to remove old motor?
Sep 20, 2009 at 5:23 AM
✓Experienced Mechanic
Actually, you don't need the brackets. After you remove the door panel, the original motor is rivited into place. Drill out the rivits and replace the new one with nuts and bolts. Make sure to use lock washers or loc-tight
Sep 22, 2009 at 1:04 AM
