2002 Chevy Impala cigarette lighters, O2 sensor location, h
75,000 MILES • 6 CYL • FWD • AUTOMATIC
NASUTE
  • 11 POSTS
Hi. I believe I fried my rear seat cig lighter when I left and air compressor plugged in too long. I changed the fuse and still nothing is happening. Also my front one, I changed the fuse, it worked for a little while but now its not working. What can I do. Also I need to replace my hazard switch cause my signals don't work properly, is this hard to do. I also waht to find my O2 sensor so I can check it and maybe replace it, but not sure what I'm looking for. Thanx for your time.
Aug 21, 2009 at 1:53 AM
JDL
  • 16,098 POSTS
Hello, as far as your cigar lighter, did you check the fuse under the hood? Underhood junction block top-- right i/p 2 fuse 60 amp.
My info shows two oxygen sensors, they are in the exhaust. One close to engine block, the other after the cat, four wire connectors.
Aug 21, 2009 at 2:14 AM
NASUTE
  • 11 POSTS
THanks. I will take a look. DO you have any pics that you can send?
Aug 22, 2009 at 12:57 PM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_02_impala_1.jpg
02 sensor.
Aug 23, 2009 at 1:53 AM
NASUTE
  • 11 POSTS
Thanx.
Aug 23, 2009 at 9:43 AM
