my 2002 impala needs inspection,check engine light won;t go off inspection guy says either a wire issue or sensor issue,what say ye?
Mar 31, 2008 at 5:16 AM
MERLIN2021
✓Experienced Mechanic
First thing you need to do is have the codes read, Autozone does it free, Post the results with the code number(s). Even if the service engine light is not on, there should be freeze frame data stored.
