2002 Chevy Impala change oil light
64,000 MILES • 6 CYL • FWD • AUTOMATIC
FRANC
I recently had the oil changed and the "change oil" light is still on on the dash board. I tried pushing the gas peddle 3 times, but a security light came on and the "change oil" light is still coming on. I don't have an owner's manual because i recently bought the cars used. HOW do i get that light off.
Feb 28, 2009 at 5:41 AM
MERLIN2021
  • 17,250 POSTS
RESETTING ENGINE OIL LIFE SYSTEM Using Radio Data System (RDS) Equipped Radio 1. Turn ignition switch to RUN or ACCY position. Ensure radio is off. Press and hold DISP button on radio for at least 5 seconds until SETTINGS message is displayed. 2. Press SEEK button up or down to scroll through main menu. Scroll until OIL LIFE is displayed. Press PREV or NEXT button to display sub-menu. RESET will be displayed. Press DISP button to reset. Chime will be heard and DONE will be displayed for one second. 3. After reset has been accomplished, scroll main menu until EXIT is displayed. Press DISP button to exit programming. Chime will verify exit. Using Accelerator Pedal Turn ignition switch to RUN position. Fully depress and release accelerator pedal 3 times within 5 seconds. If CHANGE ENGINE OIL message flashes, system is reset. If CHANGE ENGINE OIL message does not flash (remains illuminated), repeat resetting procedure.
Feb 28, 2009 at 5:56 AM
