2002 Chevy Impala Air Only Works Sometimes
49,500 MILES • 6 CYL • 2WD • AUTOMATIC
THESCHROEDMEISTER
Sometimes the fan/air will not come on. Other times, it works fine. Any quick tests before expensive diagnostics? Thanks for any help you can provide.
May 27, 2008 at 11:17 AM
RHALL77
  • 3,361 POSTS
blower motor resistors go out all the time in these vehicles. that is the most likely cause. it is located on the passenger side of the HVAC box right about where the carpet starts. it has about 5 wires going to it. use a 5.5mm socket to remove it.
May 30, 2008 at 2:12 AM
