won't stay running
190,000 MILES • 6 CYL • FWD • AUTOMATIC
MDFELGEE
car will turn over but won't stay running we changed fuel filter, spark plugs / wires, MAF sensor, and ignition module checked out
Oct 20, 2008 at 11:01 AM
RENAUDTN
  • 636 POSTS
Is your fuel pressure good?
Oct 21, 2008 at 2:29 AM
MDFELGEE
fuel pressure checked out at 55 psi we also shoot it with starter fluid and still got nothing
Oct 21, 2008 at 3:29 AM
RENAUDTN
  • 636 POSTS
Check for vacuum leaks (especially around the intake gasket, they're bad on this type of engine).
Also, check your IAC valve, MAP sensor, oxygen sensors, EGR valve.
You could also have dirty injectors.
If you have a scanner, and your car runs long enough, do the following: check your Short Term Fuel Trim (STFT) and Long Term Fuel Trim (LTFT) values. It should be between -8 an +8. If you have values greater than 10, your engine is running lean. At this point, rev the engine to 1500-2000 rpm for about one minute and check your values again: if your STFT drops down to a normal reading, you have a vacuum leak. If it doesn't change, you would likely have a problem with your fuel delivery, which in your case could be dirty injectors since you replace the fuel filter, and your fuel pressure is good.
Do you have any codes/pending codes?
Okay, I have to ask: you said you sprayed starter fluid; you would do that only if a car doesn't crank over to figure out what's missing (spark or fuel); i thought the car was actually cranking over and then stall. Do you mean that it does not even crank over?
If the car doesn't crank over, have you checked for sparks when you're cranking the car?
Oct 21, 2008 at 8:42 AM
PIERREKKK
Car will not stay started. Only stays running if I am holding down the gas pedal. I change fuel pump/fuel filter/spark plugs/wires and plugs/fuel injectors/battery/alternator.
Aug 25, 2018 at 5:33 AM
  • 55,628 POSTS
These cars had a big problem with the crankshaft angle sensor which go out all the time. We should run the codes though. Here are two guides that will help get started and the location of the sensor:
and
Cheers, Ken
Aug 25, 2018 at 7:05 AM
