2001 Chevy Impala Temperature
KENNY2001
2001 Chevy Impala 4 cyl 140000 miles
The heater is blowing out hot air and the car is running fine, but the temperature needle doesn't move at all. I replaced the temperature sensor, but that didn't fix the problem.
Any other ideas as to what it could be?
Jan 3, 2010 at 7:59 AM
ERNEST CLARK
  • 1,730 POSTS
If you are sure the new temp gauge is not faulty, then you either have a blown fuse, there's a short/bad contact on your instrument gauge panel, or a short/bad connection somewhere in the circuit between the sensor and the gauge.
Jan 4, 2010 at 9:38 AM
