2001 Chevy Impala temp guage
135,000 MILES • 6 CYL • FWD • AUTOMATIC
HOWIEL
the temp guage has apparently malfunctioned. it has spun all the way around, and now my electric fan will not stop running. i live in minnesota and the fan has hardly ever run in the winter time. any sugestions would be great
Dec 19, 2007 at 3:17 PM
2CARPRO JACK
  • 11,533 POSTS
Is it full of anti-freeze? usually the fan runs when the engine temp is around 230 F . The gauge is a problem with GM's. If you remove the cluster , you can manually move the gauge over to where it should be and it will work again 99% of the time. Check the fluid level though. Are you running the defroster when fan is on?
Dec 19, 2007 at 11:42 PM
