2001 Chevy Impala Something is not right
TKWILKINS
  • 2001 CHEVROLET IMPALA
Engine Cooling problem
2001 Chevy Impala All Wheel Drive Automatic 92000 miles
My temp gauge will not register, it tries when you first turn on the car; at the same time, there seems to be a fan that is running by the fender of the passenger side that did not do this before; coolant level is full. It just started to freeze here about a week ago. Check engine light came on when this all happened. What do you think this might be?
Tuesday, December 15th, 2009 AT 8:51 AM
MMPRINCE4000
  • 8,548 POSTS
Start by having codes read at most autoparts stores for free.
It sounds like the thermostat or gauge itself. Does it blow heat out vents or cold air?
Could also be the temp. Gauge sender.
Thursday, December 17th, 2009 AT 9:18 AM
