service vehicle soon light
CLAUDE0000
Engine problem 6 cyl Front Wheel Drive Automatic 98,000 miles
i made a mistake and post that service engine light was on no it's my service vehicle soon light is on it been on for about a month or 2 the car seems to run fine and i took it up to auto zone and they could not find no codes or nothing wrong because i guess the engine light it self is not on but i 'm still thying to figure out why the service vehicle soon light is do i need to take it to the dealer or is it something i could do to reset or fix something
Jan 7, 2008 at 7:11 AM
  • 55,649 POSTS
There are two lights check engine light and the service engine soon light.
This is the reminder light to change the oil? If so, turn the key on with the engine OFF, then press the gas pedal to the floor three times within 5 seconds, this resets the light until the next service interval.
If the check engine here is a guide to pull the codes it sounds like the scanner at the auto parts tore was not working.
Please let us know.
Cheers, Ken
Jan 26, 2018 at 4:08 AM
2001 IMPALA
Check engine light can on steady, temp gauge moved enough to turn on the fans, flushed radiator, low coolant level warning light comes on, engine chugs from stop position through acceleration, check engine light flashes then steady.
The check engine light came on for about a week and has stayed on, had it coded as EGR. then the low coolant level warning light came on would come on then turn off and on again. checked it levels were okay. started noticing sluggish starts. the temp gauge then went to hot turned the fans on. had the coolant flushed and replaced. a day later the coolant light came on again. now at a stop position thru acceleration the engine chugs during which the check engine light flashes.
Jan 26, 2018 at 8:49 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
You say your getting slugish starts so the starter is turning the engine over slower then normal?Go to the auto parts store and have them check your battery and alternator.Also what is the exact code numbers you have not the code description?
2001 IMPALA
the engine has no trouble turning over. when accelerating the engine chugs or when i first start the engine. i also noticed a carbon smell after driving say 25 miles then the engine starts chugging. i do not have the code, autozone said the code was for the ERG. this all started when the low coolant light came on.
SATURNTECH9
  • 30,869 POSTS
Heres the problem there is more then one code for the egr valve thats why i asked you what is the exact code number.I cant just guess and hope its the right code number i picked.The code is going to be are starting point in diagnosing th problem so i really need that cide number.Also you said the car was getting sluggish starts what did you mean by that?
2001 IMPALA
disregard sluggish starts. the engine turns over perfect, however the engine once started, chugs for maybe a minute then idles smooth. during driving for lets say a half hour i will come to a stop, still in drive the engine will chug and pop. i will then take off and the engine will sputter until i get to about 30 mph. during that time the check engine light will flash then stay on on steady. at the same time the low coolant level warning light goes on and then off .
CLAUDE0000
Engine problem
2001 Chevy Impala 6 cyl Front Wheel Drive Automatic 98,000 miles
i got this service engine soon light it's been on for about a month or 2 but the car seems to run fine i took it up to autozone and had them put it on the computer to see if i need a part they didn't find anything wrong do you know whys it's on or do i have to take to the dealer
  • 75,988 POSTS
The light is On-should give a code/s-have them clear the code and see what happens.
My question here why didn't they clear the code?
SATURNTECH9
  • 30,869 POSTS
Usually when the check engine light flashes on and off that means you have a bad engine miss fire can damage the cat so there should be a code for that.With the low coolant light coming on and off there should be a code for that also.As far as the chugging goes and you said you have a egr code you could have a egr valve sticking open.That could cause the chugging and the engine light to flash from a large vacuum leak causing a miss fire.But you could have a egr valve code for low or no flow and not for possibly sticking open.We can start guessing and wasting both of our time and your money.Or you can get me the exact code numbers and not code descriptions.The code numbers will be a P followed by a four digit number.I like the second option myself i hate assuming and guessing as to why the check engine light comes on.Even if i was there with you working on the car i would be reading the codes first thing.
2001 IMPALA
Thanks for your help. I will figure out the code and let you know. Your information was very helpful, thank you for your time.
SATURNTECH9
  • 30,869 POSTS
Your welocome thats what were here for.Keep me posted.
DMECKOLA
Electrical problem
2001 Chevy Impala 6 cyl Front Wheel Drive Automatic 88894 miles
I just bought a used 01 Impala LS (3.8 V6) I have driven it less than 100 miles and after putting gas in it the "service engine soon" light came on. It stayed on until I turned the car off and then 10 minutes later restarted the car and the light never came back on. What could be causing this?
RHALL77
  • 3,361 POSTS
check your gas cap and see if it is tight or sealing properly. have it scanned and see what the code is and let me know what the code is and Ill see what I can do to help
LANGSTON100
Engine Performance problem
2001 Chevy Impala 6 cyl Two Wheel Drive Automatic 200000 miles
I have a check engine light that turn on and off while driving, I flashes like may turn signal light
  • 75,988 POSTS
Go to Autozone and have the computer scanned for OBD2 code/s its a free service this is your starting point of finding out what's causing the CEL to come on and get back with the code/s
TSANDERS1906
Computer problem
2001 Chevy Impala 6 cyl Two Wheel Drive Automatic 138000 miles
I have a 2001 Chevy Impala and my engine light just popped on. However, there are no obvious symptoms that helps me figure out what's wrong. Is there a way to purchas something that will give me the trouble code or do I have to go to a dealer?
Any help will be appreciated.
BLACKOP555
  • 10,386 POSTS
lots of auto places will be able to sell you the scan tool to use, you can also go to autozone and they will scan it for you.
post back if you need help deciphering them.
LMWSLW
2001 Chevy Impala 6 cyl Front Wheel Drive Automatic 52,000 miles
Engine light on.
Mechanic said engine wasn't "sparking" properly.
Reset light (off).
Nothing "fixed".
Mechanic said I would need to leave car a few days.
Light back on the next day.
What is the problem with the engine?
OBXAUTOMEDIC
  • 3,711 POSTS
Here is what you need to do...
Take it by your local parts store and have them pull codes for you and Right Them Down. Post them here and we will assist in getting to problem and fixing it.
If it is a problem with spark or Misfiring the code should be P0300 or any of the following P0301 - P0306.
MAGGIS
I have my engine check light on after filling gas
HMAC300
  • 48,601 POSTS
make sure gas cap is tightened at least 3 click after filling you will need a scanner to shut it off. autoparts do for free.
GFENTON123
Engine Mechanical problem
2001 Chevy Impala V8 Two Wheel Drive Automatic 107000 miles
Hello, my engine light has been on forever. No shop can find the problem. Around six months ago I replaced the mass air flow, fuel filter, spark plugs, wires, pcv valve. The car was fine. The light was reset and it stays on. The past few weeks my car will not shift out of gear by itself unless I let off the gas and give it gas again. If I don't let off the gas, the car stays in first gear bringing the speed up to 60 km per hour, 4000 rpm. When this happens the engine liight flashes. Is that a misfire problem? Please help.
  • 75,988 POSTS
Check engine light coming On
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on
ED
chev 2001 impala engine light code P0171 system lean what is the problem and how to repair ir
Jan 26, 2018 at 8:50 AM (Merged)
  • 75,988 POSTS
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
SWAKELY
2001 Chevy Impala 6 cyl Two Wheel Drive Automatic 103000 miles
I just got an OBD scanner and hooked it up -it says 02 Sensor Heater Circuit Malfunction - Bank 1 sensor 1 - I can't find anything in the material that came with the machine to tell me what this means - any ideas??
Sherry
RHALL77
  • 3,361 POSTS
anytime it says malfunction, just replace it.
DEBMILLER1972
Electrical problem
2001 Chevy Impala 4 cyl Front Wheel Drive Automatic 68,000 miles
My car lights turn on at night, the door locks click but don't work anymore, sometimes the blinkers work & sometimes not, the radio locks out, the interior lights come on and flicker, the trunk opens itself. Service engine soon/ security/ change engine oil/ the battery logo all appear and flash on & off. The battery will not take a jump (it is 2 mos. old)
Then without reason it runs and all is well just fine until you turn it off and go into the store for 5 mins. when you come back out- it will not take a jump or if it did take a jump, everything is flickering and the head lights and brights are on good - then dim.
My car is crazy!
TOOOMANYTOYS
  • 513 POSTS
Sounds like you have an intermittently electrical problem. Being that so may things go haywire at random. I would start by checking all the vehicles ground connections. From the battey follow cables to there locations and insure they are tightly connected. Was any work done to the vehicle before this happen?
KNIGHT6469
2001 Chevy Impala 6 cyl Front Wheel Drive Automatic 134000 miles
my check engine light came on. a advance auto associate checked it. she gave me a trouble code.auxiliary emission control P1404
RHALL77
  • 3,361 POSTS
call your local dealer. there may be a reprogram for that code
THOMAS L PRESCOTT SR
I have a problem with my fuel tank module? It has a check engine light on?
  • 75,988 POSTS
Have the computer scanned for code/s-you have a problem within the engine engine management system-this is your starting point of diagnosis
