2001 Chevy Impala Relay Switch?
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
SAD.DAD
I have a 2001 Chevy Impala and it's having trouble turning over without a jumpstart. When I turn the ignition I hear a series of clicks coming from the fusebox and my power windows attempt to lock or relock. Also the instrument needles pulse in time with the clicks. Since the noise is coming from the fusebox, I suspect a relay of some sort...but I have no expertise to back that up. Thoughts?
Sad Dad
Aug 6, 2009 at 12:37 AM
JDL
  • 16,098 POSTS
Hello, I'd make sure the battery has a full charge, battery connections are clean and tight on both ends. If that checks out, do some testing at the starter relay in the power distribution center, under the hood. Your owners manual should show locations of fuses and relays.
Mar 6, 2021 at 10:14 AM
SAD.DAD
Thanks for the input...you were dead on. :-)
Not-so-Sad Dad
JDL
  • 16,098 POSTS
Glad you got it going your way. Also make sure the charging system is ok.
