2001 Chevy Impala Not Shifting
19,000 MILES • 6 CYL • 2WD • AUTOMATIC
SMUIR
Yesterday my Impala started to not shift when it should be. It will stay in first for a very long time and then if you let up on the gas it might change into second. Once you get on the freeway it will also downshift and rev the engine with no reason.
Jan 28, 2010 at 2:33 AM
SCOTTY DEE
  • 592 POSTS
What we are going to want to find out is if it is a transmission problem, and whether or not it's an electrical or mechanical failure.
Is the transmission fluid level correct? Check with engine running and in park.
The first thing to do is to have the PCM scanned for codes, then I can further advise you.
Jan 28, 2010 at 11:29 AM
