I would like to know where the ECM (PCM, ECC) is located on the 2001 Chevy Impala.
Oct 2, 2010 at 8:36 AM
✓Experienced Mechanic
Powertrain Control Module In air cleaner box. Here is the instructions and location of the PCM which I would get a a preprogrammed unit by searching Google or Ebay. Check out the images (below). Let us know if you need anything else.
where is the computer located on a 2001 chevy impala
Mar 1, 2019 at 11:33 AM
(Merged)
IMPALASS
Hello –
If you are talking about the PCM, Power train Control Module it is located on the left Side Of Engine Compartment, Inside Air Filter Box.
(Merged)
DRHINES22
MEMBER
1 POST
I am trying to find someone who can tell me the location of the computer on a 2001 Chevy Impala 3.4 L and possible provide a picture. Thanks
(Merged)
ZACKMAN
Inside your air filter box.
(Merged)
GOLDY
MEMBER
Where is the ECU on a 2001 chevy impala 3.8 L and how do you replace it?
(Merged)
The PCM is in the aircleaner box
(Merged)
GOLDY
MEMBER
Excuse my ignorance; but is the PCM and ECU the same thing and is it difficult to replace?
Thanks
(Merged)
Its the same thing-disconnect the negative battery cable then find it and unplug the wiring connectors-Bear in mind that you might have to go thru a computer relearning process after replacement due to battery disconnection.
(Merged)
