2001 Chevy Impala Ignition
99,000 MILES • 6 CYL • FWD • AUTOMATIC
JTORBITT
One night my key was stuck in the ignition and then it finally caame out and now I put the key in and it won't turn?
I was going to replace the lock assembly on it only, and i don't know how to get the assembly out without turning the key?
Aug 18, 2008 at 11:16 AM
RHALL77
  • 3,361 POSTS
i would at this point take the assembly to a lock smith or bust the lock cylinder to get it to turn and remove it
Aug 18, 2008 at 11:44 AM
KHOOPER
  • 22 POSTS
If you have a test light, check for continuity the wiring from the ignition-->starter, battery-->starter, ground wire from starter-->chassis ground.
Aug 18, 2008 at 12:13 PM
RHALL77
  • 3,361 POSTS
does the key itself turn or does it turn ok and the starter doesnt crank
Aug 19, 2008 at 12:17 AM
