One night my key was stuck in the ignition and then it finally caame out and now I put the key in and it won't turn?
I was going to replace the lock assembly on it only, and I don't know how to get the assembly out without turning the key?
Monday, August 18th, 2008 AT 6:16 PM
RHALL77
MECHANIC
I would at this point take the assembly to a lock smith or bust the lock cylinder to get it to turn and remove it
SPONSORED LINKS
Monday, August 18th, 2008 AT 6:44 PM
KHOOPER
MEMBER
If you have a test light, check for continuity the wiring from the ignition-->starter, battery-->starter, ground wire from starter-->chassis ground.
Monday, August 18th, 2008 AT 7:13 PM
RHALL77
MECHANIC
Does the key itself turn or does it turn ok and the starter doesnt crank
