I am having some car troubles, and wanted to get your opinion. I have a'01 Impala, and I got a message on the dash that says "Check Traction System" and it also says "Trac Off to the left of the dash and to the right it says "ABS". What could be the problem. Then my lights for the heater adjustments don't work. Also sometimes my turn signals will not work and then they all of a sudden start working again. Also, the heated seat on the driver side does not work, and the rear defrost does not seem to work 100 %. Could you give me some advice? Thanks for anything you can give.
Feb 14, 2008 at 5:48 AM
