2001 Chevy Impala fuel
2001 CHEVROLET IMPALA
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
CARRIELAL
when driving, idling, accelerating the car seems to stutter. I'd guess mis-firing, but the plugs and wires have been changed. I have also done the fuel filter. The exhaust smells rich of gas and gas mileage has become horrible, what could be causing the issue?
Jan 7, 2008 at 3:15 PM
DENNYP
  • CAR REPAIR CONTRIBUTOR
  • 1,824 POSTS
sounds like you have spark grounding out somewhere. You should re-check your plugs and wires. Make sure you don't have a corroded coil tower. You might also have a fuel pressure regulator leaking into the vacuum hose.
Jan 8, 2008 at 7:32 PM
