Oxygen Sensor(s), Catalytic converter, EGR valve could be potential problems. If the valve cover is leaking oil you will need to replace the gasket. Do a compression check on the engine just to be sure.
SPONSORED LINKS
Monday, June 23rd, 2008 AT 2:33 AM
