2001 Chevy Impala electricel
72,000 MILES • 6 CYL • FWD • AUTOMATIC
KPOM01
I need to run 4 large wires (strobes) through the firewall, i can see a few places where wires are run through but all are innaccesible from one side or the other, i have removed the dash, radio, consoles, glove box, and have found nothing, is there somewhere else i should be looking or do i need to drill a hole
Feb 19, 2008 at 4:41 AM
DENNYP
  • 1,824 POSTS
You will need to drill a hole. Be sure to seal the hole with a marine grade silicone sealer after the wires are through.
Feb 19, 2008 at 1:41 PM
KPOM01
thanks! i drilled the hole, below the glovebox area, i had to cut out a small portion of the really thick 2 layer insulation around the area that i have never seen before, any idea on where i can buy some to patch it? or should i not even worry about it as i am going to be COATING it in rtv sillicone?, thanks again!!
Feb 19, 2008 at 5:54 PM
DENNYP
  • 1,824 POSTS
I wouldn't worry about the insulation. The silicone should seal everything up.
Feb 19, 2008 at 11:06 PM
KPOM01
THANKS!!!
Feb 21, 2008 at 6:02 PM
