2001 Chevy Impala EGR Valve
109,000 MILES • 6 CYL • FWD • AUTOMATIC
ELEMENT
My check engine light came on, I went down to Auto Zone and had them do a check engine diagnostic, and it came back as EGR Valve failure. I replaced my EGR Valve and had them reset the light, and it went off, but about 15 minutes later, the check engine light came back on. I checked the connection of the valve and the wires connecting into it, and everythings connected properly. What is going on and what should I do?
Nov 12, 2008 at 2:22 PM
RHALL77
  • 3,361 POSTS
what was the code number
Nov 13, 2008 at 2:01 AM
DENNYP
  • 1,824 POSTS
The EGR passage in the upper intake manifold is probably restricted with carbon deposits. You will have to clean it out with a coat hangar wire and some good cleaner. (GM Top Engine Cleaner) or (Sea Foam)
Nov 13, 2008 at 4:28 AM
GUZMAN
Hi
I just bought my 2001 chevy impala and i am having the same problem. It struggles to start and the check engine come on. ONce i was dirving and it just stopped on me. I have no clue what it can be
Nov 25, 2008 at 2:02 PM
