2001 Chevy Impala coolant temp gauge
135,000 MILES • 6 CYL • FWD • AUTOMATIC
SSHEPPARD9804
The temp gauge in my car does not work properly, sometimes not at all. I replaced the sensor/sending unit and I thought it was working correctly, but today it didn't even move while I drove 85 miles. When I got home the fan came on and ran for about 5 min. Is the gauge bad or where else should look for the problem? Thanks.
Jan 2, 2008 at 10:14 AM
  • 75,988 POSTS
Check the wiring/connections for the temperature gauge if it checks out-the gauge could be out of calibration.
Jan 2, 2008 at 10:17 AM
  • 75,988 POSTS
He didn't mentioned anything about overheating that gauge was his concern-its gonna give a reading with or without the Stat.
Jan 11, 2008 at 2:50 PM
  • 75,988 POSTS
Test the coolant temperature sensor or replace it
Jan 12, 2008 at 6:35 AM
  • 75,988 POSTS
Guessing/coincidence is not answer but theory speaks for itself in engine management system/performance
Jan 12, 2008 at 11:50 AM
MUDDYBLAZER
[quote:3838776c4e="rasmataz"]Guessing/coincidence is not answer but theory speaks for itself in engine management system/performance[/quote:3838776c4e]
any how it sovled the problem of his car.
Jan 13, 2008 at 2:22 AM
