2001 Chevy Impala 6 cyl Automatic 182000 miles
My battery died and i swapped it with another battery that My brother had for his car and then went to the auto parts store and had them replace the battery. They hooked some kind of memory thing in under the dash then changed the battery when the un pluged the box they had plugged in everything in the car went off and the car would not start they checked all connections and then plugged the box back in all lights started working again and the car would start they unplugged and the car stayed running and will start when turned off however the power locks, auto headlights speedometer and rpm , inside lights and dash light none of them work and the radio(factory) says locked on it ... any suggestions on how to fix this or what needs to be done.... Thanks
Oct 1, 2009 at 12:51 PM
