i have an 01 chevy impala i just replace the starter, got up this morning it wouldn't start. what could be the problem
Sep 20, 2009 at 5:31 AM
✓Experienced Mechanic
Is the new starter working? If not, have you checked the starter relay?
If the starter isn't working, have a helper turn the key to the start position while you check for voltage to the smaller wire on the starter. You should be getting 12+ volts.
