2001 Chevy Impala
TIMMYA
Other Category problem
2001 Chevy Impala 6 cyl Two Wheel Drive Automatic
how do you fix a code po401
Feb 6, 2008 at 11:15 PM
BLACKOP555
  • 10,386 POSTS
PO401 is the code for insufficent EGR flow.
most likely the cause is the ports of the egr is plugged up with CARBON! and a simple clean will get it running again.
but sometimes its not that simple.
the EGR valve could be defective and need replacing, it could not be reciting vacuum due to a bad vaccum line, or it could be due to a faulty DPFE sensor for the EGR.
Mar 23, 2008 at 1:53 AM
