2001 Chevy Impala
ANZALONE2
Engine Cooling problem
2001 Chevy Impala Front Wheel Drive Automatic 180000 miles
my car has started to overheat and noticed neither one of my fans are working. Is it possible that is it just a fuse?
Aug 31, 2010 at 11:54 PM
  • 110,248 POSTS
It could be just a fuse or relay. Does it only overheat when the car is in stop and go traffic or does it do it at highway speeds too?
Jan 31, 2019 at 10:47 AM
ANZALONE2
It has happened twice when I was in bumper to bumper traffic on highway. When the car started getting to hot I pulled off and waited for engine to cool down and traffic to start moving. Once I was moving again - engine stayed normal temp.
  • 110,248 POSTS
The fans not turning on is the problem. When you are hardly moving or stopped, there is no air flow. That is when the fans need to come on. When you are moving, air flow happens from the vehicle moving. Thus, it doesn't overheat.
The first thing I need to know is if the fans are good or bad. Take a jumper wire from the battery to the fan motor to see if the engine runs. Let me know what you find.
