2001 Chevy Impala
178,889 MILES • 6 CYL • 2WD • AUTOMATIC
VGONZAL15
ac works sometimes it is not working right now it only blows hot air notice it happens when i use the defrost or the heater also the fan outside i was told i had to disconnect battery and connect it back an it would work i tried it didnt work
Feb 25, 2009 at 1:33 PM
BMRFIXIT
  • 19,053 POSTS
Need to check if you system full or not
check fuses
check for codes
if system low will not work and need to be checked
Feb 25, 2009 at 9:00 PM
