2001 Chevy Impala
KHALI102
2001 Chevy Impala 6 cyl 78000 miles
Hi I have had my used impala for about 7 months now and my turning signals only work when they want to. I've had new brakes put on about 3 months ago and they are squeaking again already. my coolant light comes on every now and then. My gas runs out very quickly, I can watch the meter moving as I drive. When I turn on the heat it smokes and smells like something is burning. It drives funny sometimes like its skipping or something I dont know much about cars. I havent had a tune-up since I got it just a few oil changes. Also in the summer when I first got it the air would stop blowing for a few only minutes at the most. Oh and I have a spare key only and I have to jiggle the key back and forth for it to turn all the way I was wondering if it would cause a problem.
Feb 15, 2009 at 11:17 AM
BMRFIXIT
  • 19,053 POSTS
WOW!
Key will cause u a problem sooner or later and should have it taken care of
need to take car in for check
I would suspect coolant leak from the intake manifold gasket and if so and doing the job
this will be the time to do the tune up and thermostat too
brakes possible dust but I would have them checked just on the safe side
if they just done they should be warranted
good luck
Feb 15, 2009 at 2:06 PM
