2001 Chevy Impala
78,900 MILES • 6 CYL • 2WD • AUTOMATIC
GXMONTES
My car starts with no problem in the morning or after it has been off for several hours. However, anytime less than that is very difficult (when the engine is still hot). In fact the only way it will start is if I hold the pedal to the floor as when trying to start a flooded car. I am afraid of damaging the cat converter starting this way. It runs great other than this problem. I have replaced the fuel filter so far.
Apr 18, 2008 at 1:35 PM
MASTERTECHTIM
  • 4,750 POSTS
99 percent sure you have a ruptured fuel pressure regulator. very easy and inexpensive to replace. remove the vacuum line to it and if you see any signs of fuel then replace it.
Apr 18, 2008 at 1:40 PM
