2000 Chevy Impala Wiper Problem
NIKHIL_LELE
2000 Chevy Impala 4 cyl 162000 miles
I have a problem with the wipers in my Chevy Impala 2000 model car. The problem is that the wipers do not turn off even when the wiper switch is turned off. I got the wiper motor and the wiper switch replaced and the fix worked for few days. But when it rained, the same problem started again and I ended up wasting $200 odd without the problem getting solved yet. I have observed that when it rains, there is some water flow sound coming from the front dashboard of the car. So I am thinking that the water messes up the wiper circuitry board and shorts it. So I believe a fix to the water problem is required first and then probably replace the wiper circuit board again.But I am not sure what is the exact problem. Any help would be highly appreciated.
May 21, 2010 at 8:01 AM
HMAC300
  • 48,601 POSTS
you are porbably right abou tyour water problem as electronics don't care for water. you may try putting a large piece of rubber or plastic over it to stop the intrusion. Also there should be a gasket between the motor and front of dash. good luck
May 30, 2010 at 5:11 AM
