2000 Chevy Impala Window motor/starting
127,000 MILES • 6 CYL • FWD • AUTOMATIC
MCDADDY5
Replace my left window motor, but did not work.
Power is going to the motor but it only clicks in the down position. Now the vehicle will not start and makes a nosie through the speakers. There is not any power for lights or anything. The battery seems to check out just fine. Nothing works in the care.
Nov 21, 2009 at 11:06 AM
  • 110,251 POSTS
Have you load tested the battery? Have you checked the grounds to the engine block, body grounds, and are the battery terminals clean and tight?
Nov 21, 2009 at 3:25 PM
