2000 Chevy Impala STARTING WHEN HOT
100,300 MILES • 6 CYL • FWD • AUTOMATIC
SRS61
The car runs and starts great, but after the engine reachs running temp if it is turned off it won't start after it sets for 15 min. The car has to set till it cools off and then it will start fine. I changed the crank and cam sensor, ignition coils, ingnition module, mase air flow sensor. isc motor, fuel pressure reguator. I also checked the fuel injectors for leaks. When trying to start hot it tries but it kind of disels and cut off.
Apr 22, 2010 at 5:26 AM
RHALL77
  • 3,361 POSTS
have you checked to see if your loosing fuel pressure or spark? we need to know this to further help you. let me know what you find
Apr 22, 2010 at 7:52 AM
SRS61
It was the fuelressure thanks for your help.
May 3, 2010 at 10:36 AM
2 LINSEY
  • 287 POSTS
Hi srs61, Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
May 5, 2010 at 5:23 AM
