The car runs and starts great, but after the engine reachs running temp if it is turned off it won't start after it sets for 15 min. The car has to set till it cools off and then it will start fine. I changed the crank and cam sensor, ignition coils, ingnition module, mase air flow sensor. isc motor, fuel pressure reguator. I also checked the fuel injectors for leaks. When trying to start hot it tries but it kind of disels and cut off.
Apr 22, 2010 at 5:26 AM
