2000 Chevy Impala Single Light
125,000 MILES • 6 CYL • FWD • AUTOMATIC
FRANK PERKINS
Whn I turn the singlr light on it does not flash. It makes a buzzing noise fron under the dash as if there is a relay there. It makes the same niose when the emergency flashers are on. The light come on but do not flash
Oct 26, 2010 at 2:01 AM
LEGITIMATE007
  • 5,121 POSTS
you need a flasher fuse. should be right under the dash by the steering column if not in the fuse box.
Oct 26, 2010 at 3:06 AM
