2000 Chevy Impala Rear wheel bearing assembly.
WILLIAM WILBURN
Drive Train Axles Bearings problem
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic
I am trying to change the rear wheel bearing assembly.
I removed the caliper,rotor,and 4 bolts holding the assembly in. The old assembly will not come off.
I'm assuming that it presses in when tightening,and is probably "corrosion welded".
How do I get the assembly off ?
Thank You.
Jan 2, 2010 at 9:28 PM
ERNEST CLARK
  • 1,730 POSTS
Just take a hammer and apply some taps to the side and back to loosen it. You don't have to worry about being gentle.
It should come right off.
Jan 4, 2010 at 10:00 AM
