Drive Train Axles Bearings problem
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic
I am trying to change the rear wheel bearing assembly.
I removed the caliper,rotor,and 4 bolts holding the assembly in. The old assembly will not come off.
I'm assuming that it presses in when tightening,and is probably "corrosion welded".
How do I get the assembly off ?
Thank You.
Thank You.
Jan 2, 2010 at 9:28 PM
