2000 Chevy Impala Problems after disconnecting stereo.
13,200 MILES • 6 CYL • FWD • AUTOMATIC
LJFRANEY
I plan to install an aftermarket stereo in my 2000 impala. I purchased a relocation harness for the factory head unit since it controls the oil life monitor, tire monitor, etc. I want to put it in my trunk. I unplugged the factory head unit, plugged the relocation harness into the radio harness, and plugged the head unit into the relocation harness. It worked like it is supposed to, I believe. I put everything back the way it was, and noticed that my service engine light is on, my airbag light is on, and my driver's side power lock no longer works. Any ideas?
Jul 23, 2009 at 3:03 AM
LJFRANEY
Looks like I had left a bolt loose that was holding in the wiring panel in the driver's side fuse box. When I tightened the bolt, the power lock began to work and the airbag light went off. The service engine light is still on. I'll look that up later with my friend's OBD-II scanner. It might just need to be reset.
Jul 23, 2009 at 4:59 AM
