2000 Chevy Impala please help
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
KAREN BECK
i get my oil checked every three months at a local car place - they check it out each time - this time they say i need remanufactured rack and pinion asssembly and change of power st. fluid. is it dangerous if it goes out ?? how do i know if i need to do it right now ?? what is a reasonable price ?
Sep 16, 2009 at 2:54 AM
  • 110,248 POSTS
Are you having any trouble turning or are you hearing any strange noises when turning? As far as replacement, if neither of the items I mentioned exist, it may be starting to leak and that is what they saw. It can last that way for a long time before going bad completely. I recommend having a second opinion. If you were not having any trouble prior, chances are it will be fine.
Also, a remanufactured rack is usually around 200.00 and figure 2 or 3 hours labor.
Sep 22, 2009 at 3:44 AM
