2000 Chevy Impala Oil in coolant tank
2000 CHEVROLET IMPALA
111,000 MILES • 6 CYL • 2WD • AUTOMATIC
EMPREL2
I am getting a LOW COOLANT light every once in a while. I found oil in my coolant when I went to add some. There was some black on the funnel when we pulled it out. What do you think?
May 11, 2008 at 5:52 PM
ROB2008
  • 258 POSTS
Does the vehicle smoke when it's running ? If so you may have a cracked head gasket.
-Rob
May 11, 2008 at 6:25 PM
EMPREL2
[quote:26bd6213db="emprel2"]Engine Cooling problem
2000 Chevy Impala 6 cyl Two Wheel Drive Automatic 111000 miles
I am getting a LOW COOLANT light every once in a while. I found oil in my coolant when I went to add some. There was some black on the funnel when we pulled it out. What do you think?[/quote:26bd6213db]
It doesn't smoke.
May 11, 2008 at 6:49 PM
ROB2008
  • 258 POSTS
Typically means you've got a blown head gasket.
The head gasket seals off the combustion chambers as well as the oil and water as it circulates between the head and the block. Sounds like the head gasket has gone bad between the oil and radiator fluid and the two fluids are mixing.
I'd get it checked to verify that it is indeed oil in the radiator fluid, or just very dirty radiator fluid.
May 11, 2008 at 7:02 PM
EMPREL2
I was told it could be an intake valve gasket - about $700? Any thoughts?
May 11, 2008 at 7:21 PM
ROB2008
  • 258 POSTS
Check the oil to see if it is clear or muddy. If it looks like mud or chocolate milk then it is an intake manifold gasket.
One word of caution, if the oil is muddy or brown in color don't drive it, you will ruin the bearings.
-Rob
May 11, 2008 at 7:36 PM
ROB2008
  • 258 POSTS
Also , If you do a compression check it should give you a good indication of whether or not the head gaskets are bad.
-Rob.
May 11, 2008 at 7:40 PM
