2000 Chevy Impala low tire pressure light
WESHAUN ANDERSON
Tires and Wheels problem
2000 Chevy Impala 141000 miles
I have beendealing with this for the past few days the low tire pressure light stays oc all of the tires have the same amount of air what else could this be
Dec 2, 2008 at 7:05 PM
BMRFIXIT
  • 19,053 POSTS
Using Exterior Lamp Switch
1.Turn ignition switch to OFF position.
2.Ensure all tire pressures are adjusted to the pressure recommended on tire pressure label. 3.Turn ignition switch to ON position, with engine off.
4.Cycle the exterior lamp switch from OFF to parking lamps 3 times within 5 seconds.
Dec 2, 2008 at 10:17 PM
