2000 Chevy Impala just bought this impala. hundred thousa
100,000 MILES • 6 CYL • AWD • AUTOMATIC
TJTRUE123
Please tell what test should be done to find any problems that might exist or parts that need to be replaced. Thanks for your time.
Ted in Seattle
Sep 22, 2010 at 9:55 AM
RENAUDTN
  • 636 POSTS
Intake vaccum test, compression test, fuel pressure test, cooling system pressure test, check ABS/ BCM/PCM with appropriate scanner for trouble codes. Make sure all the accessories work, turn on AC and make sure the cooling fans come on. Check your brakes, and brakes lines. Check your struts/springs (rule of thumb is if you push down on the car and let go it should come back up with almost no bouncing). Crawl under the car and check for leaks or signs of leaks.
That’s a good start. Good luck
Sep 23, 2010 at 2:29 AM
