2000 Chevy Impala Idle Air Control Valve
2000 CHEVROLET IMPALA
153,000 MILES • 6 CYL • FWD • AUTOMATIC
KJ7100
  • 5 POSTS
My 2000 Chevy Impala idles extremely high when I pull up to a stop sign or put the car in park. It makes a loud whirring noise when not moving. It sounds like the accelerator is being pressed down.
Could it be the idle air control valve needs to be cleaned? How difficult is this? And where is it located?
Thanks for your help!
Jul 21, 2008 at 9:21 PM
RHALL77
  • CAR REPAIR CONTRIBUTOR
  • 3,361 POSTS
it could be. Is there a check engine light on? I would check for a vaccum leak first.
Jul 22, 2008 at 8:29 AM
KJ7100
  • 5 POSTS
No check engine light. When you say vaccuum leak, what exactly does that mean?
By the way, this morning it was fine so the high idling seems to be intermittant. It happens about every other day and when it is really hot outside.
Jul 22, 2008 at 10:40 AM
RHALL77
  • 3,361 POSTS
a vacuum leak is when the engine is sucking air from a broken vacuum line or a broken gasket. you would hear a hissing noise under the hood. sounds more like a temp sensor or a maf sensor since your talking about outside temp. you will need a scan tool to read those sensors to see what they are doing.
Jul 22, 2008 at 3:27 PM
KJ7100
  • 5 POSTS
I am so sorry to keep bothering you, but now the flash engine light is flashing. I am going to take it to the mechaninc, do you still think this is a vacuum leak? Is this an expensive repair? Any other suggestions as to what it could be? The engine seems to be shimmying, the ride is much rougher now. I am considering trading the car off, so any advice/information you have is very helpful.
Thanks!
Jul 26, 2008 at 7:15 PM
