2000 Chevy Impala fuel pump runs when key turned to ACC,
93,000 MILES • 4 CYL • FWD • AUTOMATIC
YANKEECATTER
  • 13 POSTS
Hi I have a 2000 chevy Impala which when I got it,it wasn't getting power to starter when key turned to start.
Finally corrected that with new Ignition Cylinder (I did the switch also.)The message center continuely shows battery then low fuel,then security in message box.Radio won't play when car is running.I turn the key from Off to ACC and I hear the fuek pump run with out going to the "On" position.The car starts,now,but something else is mess-up.The fuel tank is full as far as I can tell,because I poured gas in and it over flowed out the filler tube.,so is there suppose to be power to the fuel pump when the key is turned to ACC?
Thanks any help will b greatly appreciated.
Ron M
Aug 30, 2009 at 10:40 AM
  • 75,988 POSTS
The ACC does not power the fuel pump its on the run position-double check your work on the switch and lock your problem is coming from there.
Aug 30, 2009 at 10:50 AM
YANKEECATTER
  • 13 POSTS
i wish it was that simple.there's only one way the two plugs that go to the ignition switch can go.any other ideas?
Aug 30, 2009 at 1:19 PM
MMPRINCE4000
  • 8,548 POSTS
If you still have the old switch, have a locksmith rebuild it.
I have seen many aftermarket switches that simply do not work.
Is your security light flashing?
Sep 4, 2009 at 12:50 AM
