2000 Chevy Impala engine stalls code p0452
DPTENN
Electrical problem
2000 Chevy Impala 6 cyl Front Wheel Drive 108000 miles
ran scan pulled code p0452 a'z says to buy fuel tank pressure sensor and replase i did. same code came back up. Is there any other sensor that can trigger this code. i plan to replace the fuel filter tomarrow. and check the fuel pressure on it. thanks for the help and great site! sorry for the post of the wrong code here's what i got today freeze fram
calc load % 0.0
coolant 190
st. ftrm1 % -0.7
lt. ftrm1 % -3.9
map(in.hg) 29.2
Mar 30, 2009 at 12:22 PM
RHALL77
  • 3,361 POSTS
you have a evap problem not a fuel system problem. You need to obtain a scan tool that can read data so we can seee what the pressure is in the tank. you may need a new evap canister. it is either plugged or the charcol in it has let loose into the evap lines.
Mar 31, 2009 at 1:14 AM
