2000 Chevy Impala Code PO304
28,000 MILES • 6 CYL • FWD • AUTOMATIC
KARO89
Hi I was just leaving my house and the check engine light started flashing and this code is what came up. I was wondering what I can do to fix the problem. Do you have any ideas what to do?
Oct 18, 2008 at 4:24 AM
KARO89
[quote:03e2e81f8b="karo89"]Engine Performance problem
2000 Chevy Impala 6 cyl Front Wheel Drive Automatic 28000 miles
Hi I was just leaving my house and the check engine light started flashing and this code is what came up. I was wondering what I can do to fix the problem. Do you have any ideas what to do?[/quote:03e2e81f8b]
Oct 18, 2008 at 4:32 AM
RENAUDTN
  • 636 POSTS
Do you have any symptoms? (car stumble, hard to start...)
This code means your 4th cylinder is not firing properly.
A number of things could trigger this code:
bad Spark plug/wire/ignition module/coil/fuel injector
burn exhaust valve
poor compression
O2 sensor
clogged catalytic converter
If your car doesn't have any symptom, try to delete the code and see if it comes back. If it does, you'll have to check what I mentioned above
Oct 20, 2008 at 2:17 AM
